Please help me identify my mystery left over bolt!!!
radrob
Post by radrob » Sat Sep 19, 2009 8:21 pm
Guys after the Bongo experience from hell which i shall unload another time, my second cylinder head change, this time with new piston has left me with a bolt that was labelled but the writing faded in the sun. I havent got a clue where it goes any suggestions please.
It is about 80mm long and with a length of plain shank, without any markings on head etc, It looks clean like it lives in a clean zone and has slightly grubby end threads as if the very end protruded. I have enclosed a piccie. The beast newly assembled seems to run without it but left-overs are always a cause for concern. PS any advice on cylinder heads give me a yell I`m sadly quite aquainted with the task.
Jeeze how do I upload a piccy?
Regards
Rob
Re: Please help me identify my mystery left over bolt!!!
Post by Doone » Sat Sep 19, 2009 8:24 pm
The pic may help with identification, instructions on how to upload a photo are HERE.
Post by g8dhe » Sat Sep 19, 2009 8:28 pm
To upload pics then take the link here and click the appropriate subject.
Sorry to here about your woes, hope all goes better now at least.
radrob
Post by radrob » Sat Sep 19, 2009 8:31 pm
http://i90.photobucket.com/albums/k245/ ... G00163.jpg
Cheers guys theres the URL
Regards
Rob
maxheadroom
Post by maxheadroom » Sun Sep 20, 2009 5:26 am
looks like a bolt from inside the car, it's not from around the gear shift or engine cover is it? :D
Keep the Faith
wonkanoby
Post by wonkanoby » Sun Sep 20, 2009 6:44 am
sure its not a head bolt assuming you used new ones?
just saw the 80 mm
in that case reminds me of bolt holds the gear shift on
radrob
Post by radrob » Sun Sep 20, 2009 8:51 am
Thanks for the advice so far. It's not a within engine bolt and doesn't hold the manual gearstick assy on or the big cross engine panel it seems too long the type of thing that would secure a clamp. I am mostly clueless.
Regards
Rob
Post by bigdaddycain » Sun Sep 20, 2009 9:05 am
I've actually got a couple of these bolts in my toolbox! I wish i could remember where they are from! #-o
radrob
Post by radrob » Sun Sep 20, 2009 9:55 am
That's more worrying than one,what job were you doing?
brorabongo
Post by brorabongo » Sun Sep 20, 2009 12:20 pm
Did you have the alternator off? The bolt looks like one of the few different ones used on the alt....I think. :oops:
ボンゴの激怒 pictures
radrob
Post by radrob » Sun Sep 20, 2009 5:44 pm
The alternator was only loosened and the bolt seems too clean but I'll double check.
Mike Jill and Emily
Post by Mike Jill and Emily » Mon Sep 21, 2009 7:55 am
It must be the Nut and Bolt Fairies,
The little blighters come along when you are doing a job like this and drop an extra in just to confuse you :lol:
I had an old Moped, and everytime I took the gearbox to bits I always ended up with a spare circlip left over :roll:
Post by bigdaddycain » Mon Sep 21, 2009 11:56 am
brorabongo wrote:Did you have the alternator off? The bolt looks like one of the few different ones used on the alt....I think. :oops:
That's it! The bolts i have that look like that are definitely from an alternator! But that particular one DOES look too clean :? I hope nowt has dropped off/clattered yet radrob? :shock:
radrob
Post by radrob » Mon Sep 21, 2009 7:43 pm
Hurrah the mystery is over and Hussain has a home!! He fits through the lower part of the rear cam cover plate, just above the lower cam pulley and needn`t have been removed hence missing him on the refit. I did have to remove the cam cover again but I`ll sleep soundly. Touch wood after two months of dead bongo it seems to be running beautifully - touch wood again etc.
The end threads that looked grubby protrude just next to the fuel pump so I was on the right line. Thanks to everyone who took time out to try and help me It was very much appreciated. The EBay cowboy who sold me the crap cylinder head still hasn`t collected the mal-machined heap but I`m hoping the whole saga will end well.
Keep on rollin.
Regards
Rob
brorabongo
Post by brorabongo » Mon Sep 21, 2009 7:48 pm
Nice one, and hope you get back to the joys of ownership.
ボンゴの激怒 pictures
