Towing an automatic bongo
wugabuga
Post by wugabuga » Mon Aug 24, 2009 7:57 pm
I'm off to festival where it often gets bogged down (crappy forecast too) and some cars require a tow out. Is it safe to tow a 2.5 diesel automatic for a short distance with the tranmission in neutral?
Thanks.
maxheadroom
Re: Towing an automatic bongo
Post by maxheadroom » Mon Aug 24, 2009 8:00 pm
should be ok but keep the engine running :D
Keep the Faith
wugabuga
Post by wugabuga » Mon Aug 24, 2009 8:03 pm
Cheers Max, assuming keeping the engine running lubricates the gearbox.
Post by Doone » Mon Aug 24, 2009 8:04 pm
And don't exceed 20mph. :wink:
Post by missfixit70 » Mon Aug 24, 2009 8:06 pm
Surely if you're being towed out, you'll want to assist with a bit of drive (or rather into L1) when you can?
Post by Doone » Mon Aug 24, 2009 8:09 pm
That's right it can be in drive, gentle revs so you don't bury it in the mud.
dandywarhol
Post by dandywarhol » Mon Aug 24, 2009 9:52 pm
Usual soggy Solfest eh? :?
Bongoplod
Post by Bongoplod » Mon Aug 24, 2009 10:17 pm
If you are anticipating a `tow`,I assume you have a 2WD,but you havent confirmed that in your post.
If you actually have a 4WD,you`ll be surprised just how good it is to get you off a muddy field.
Ive got off plenty with my caravan on the back,when others have struggled.
Brian
Post by missfixit70 » Mon Aug 24, 2009 10:22 pm
I've never needed a tow yet with my 2wd :wink: & the worst camps mudwise, I've been towing a fairly heavy trailer.
