Towing an automatic bongo
I'm off to festival where it often gets bogged down (crappy forecast too) and some cars require a tow out. Is it safe to tow a 2.5 diesel automatic for a short distance with the tranmission in neutral?
Thanks.
Thanks.
- maxheadroom
Re: Towing an automatic bongo
Cheers Max, assuming keeping the engine running lubricates the gearbox.
And don't exceed 20mph.
- missfixit70
Surely if you're being towed out, you'll want to assist with a bit of drive (or rather into L1) when you can?
That's right it can be in drive, gentle revs so you don't bury it in the mud.
- dandywarhol
Usual soggy Solfest eh?
If you are anticipating a `tow`,I assume you have a 2WD,but you havent confirmed that in your post.
If you actually have a 4WD,you`ll be surprised just how good it is to get you off a muddy field.
Ive got off plenty with my caravan on the back,when others have struggled.
Brian
Brian
- missfixit70
I've never needed a tow yet with my 2wd
& the worst camps mudwise, I've been towing a fairly heavy trailer.
