Help - Broken back light!
bongoSal
Post by bongoSal » Thu Aug 13, 2009 3:22 pm
I have just reversed into a post and have smashed the red bit of plastic covering the break light! cant seem to see a replacement in the shop! Any advise please! x
Re: Help - Broken back light!
Post by Ian » Thu Aug 13, 2009 3:36 pm
You have to buy the whole unit I'm afraid, or do a bodge. The units are in the "exterior" section of shop.
Post by bigdaddycain » Thu Aug 13, 2009 3:42 pm
You will in all likelyhood need a complete replacement rear lamp i'm afraid. In SOME cases repair tape can be used, but it's not ideal really.
There are three different types of lamp for the bongo... The early type have an orange coloured indicator section, the facelift type have the indicator section in a clear plastic, the latest type is substantially different. Please check which type you'll need before placing an order (wherever you do source one from).
http://cgi.ebay.co.uk/Mazda-Bongo-Freed ... 286.c0.m14
http://cgi.ebay.co.uk/New-tail-light-un ... 286.c0.m14
In the meantime, (whilst a light is being sourced) Pop round to your local car accessory shop and ask for a bulb with a red globe instead of clear, as it's illegal to show a clear/white light to the rear. Failing that, treat yourself to a box of Cadbury's roses, you will find that the red transparent wrapper to the "Brazilian darkness" choccy will wrap nicely around the globe of your bulb,meaning your light glows red till you can get it repaired properly! :wink:
Post by bigdaddycain » Thu Aug 13, 2009 3:49 pm
Ian wrote:You have to buy the whole unit I'm afraid, or do a bodge. The units are in the "exterior" section of shop.
I wasn't (of course) advocating that the lamp should be sourced via e-bay... It was a convenient source of pics to differentiate from one type of lamp to another... :wink:
bongoSal
Post by bongoSal » Thu Aug 13, 2009 4:08 pm
Thank you both very much - An expensive morning!
David Edwards
Post by David Edwards » Thu Aug 13, 2009 6:14 pm
If it is just a small(ish) hole like mine had then it is repairable with some rigid plastic in a kit, let me know and if you want one I can always get it from my famous "What" shop for a couple of quid and post it to you no probs. I found the light cluster on evil bay to be around £70 or so which is a stupid price, just because it has the name bongo parts are at a criminal price.
Post by missfixit70 » Thu Aug 13, 2009 6:55 pm
Most of the larger cheapy type shops tend to stock the repair kits for a pound or two with the appropriate hard coloured plastic panels you cut to size, I always carry some with me.
bongoSal
Post by bongoSal » Fri Aug 14, 2009 4:55 pm
Thanks all - My lovely boyfriend has fixed it!
David Edwards
Post by David Edwards » Fri Aug 14, 2009 6:16 pm
See easy peast, job done, lol, I carry a pack of each colour too, £2.50 a pack with us and well worth having the three colours, Red, clear and orange.
