Help My Roof Wont Rise!
Vicky007
Post by Vicky007 » Sun Aug 09, 2009 8:53 pm
Been camping this weekend and went to raise my auto freetop roof the dashboard light for the roof comes on and goes off like normal but when u press the botton to raise the roof nothing, no sound or movement, could it be a fuse that has blown somewhere? and if so where am i likely to find the fuse any help gratefully received.
thomas104
Re: Help My Roof Wont Rise!
Post by thomas104 » Sun Aug 09, 2009 9:06 pm
without sounding like a silly did you have the handbrake on and in nuetral !! just something i did not do one time
Vicky007
Post by Vicky007 » Sun Aug 09, 2009 9:15 pm
yeah checked all that first once i new there was a problem.
Post by g8dhe » Sun Aug 09, 2009 9:22 pm
The AFT fuse is number 12 and is 30Amps its located middle row fourth from left.
Post by missfixit70 » Sun Aug 09, 2009 9:25 pm
Fuse is no 12, 4th from left on the second row, should be a green 30 amp fuse, if you look in the fusebox factsheet in the members area it shows it.
If you lift the plastic console, there's a switch at at the back of the handbrake, quite often this gets damp, oxidises & doesn't work, give the switch a good scrape on the faces that make contact, chances are that'll solve it. Give me a shout if not Vicky :wink: .
Beat me to it Geoff :lol:
dom_e
Post by dom_e » Sun Aug 09, 2009 10:08 pm
I thougth it had to be in 'park' with the handbrake on for the roof to raise.
Beyond A to B
Post by missfixit70 » Sun Aug 09, 2009 10:24 pm
Shouldn't matter what gear it's in as long as the handbrake is on, mine goes up in any gear.
Vicky007
Post by Vicky007 » Tue Aug 11, 2009 8:27 pm
Roof is now rising perfectly was down to the hand brake switch thing so panic over thanx guys.
aitch
Location: in a place far, far away, well Somerset for now!!!
Post by aitch » Tue Aug 11, 2009 8:32 pm
A quick fix - the type we like to hear about well done you =D> =D> =D>
Post by missfixit70 » Tue Aug 11, 2009 10:17 pm
Seems to sort most of them :wink: Same thing happened to Hotpot when she turned up at the Bash, luckily she was pitching behind me, so it was instantly sorted, just as well as it was nearly 1 am :wink:
