Disconneted lead next to the battery?
Betty Bongo
Post by Betty Bongo » Wed Jul 29, 2009 4:05 pm
Just popped the bonnet to have a proper look and there is a lead encased in blue plastic attached to the body work just above the battery but the other end does not have a fitting and not attached anywhere, where does it belong?
Your thoughts much appreciated.
sparkymik
Re: Disconneted lead next to the battery?
Post by sparkymik » Wed Jul 29, 2009 4:14 pm
How many batt's has your Bongo? might be two, so you have the northern winter pack and it could be the extra if it's on the left, usefull for convertion to a leisure batt
Sparky
Betty Bongo
Post by Betty Bongo » Wed Jul 29, 2009 4:26 pm
Only one battery fitted and the lead is the length that it should be connected to something to do with the battery.
Triple/R
Post by Triple/R » Wed Jul 29, 2009 4:32 pm
Betty Bongo wrote:Only one battery fitted and the lead is the length that it should be connected to something to do with the battery.
Hi & welcome Betty Bongo--besides your main battery is there another battery tray with no battery there-- just below your coolant level filler ??????????
Regards Ray & Christine
Betty Bongo
Post by Betty Bongo » Wed Jul 29, 2009 5:00 pm
No second battery tray under the coolant. The lead is only 30cm long and is on the drivers side next to the battery.
waycar8
Post by waycar8 » Wed Jul 29, 2009 5:03 pm
Betty Bongo wrote:No second battery tray under the coolant. The lead is only 30cm long and is on the drivers side next to the battery.
Do you have 2 leads coming off the battery??????? 1 on the positive and 1 on the negative
Betty Bongo
Post by Betty Bongo » Wed Jul 29, 2009 5:14 pm
Yep! Fiddling about to upload a picie.
Betty Bongo
Post by Betty Bongo » Wed Jul 29, 2009 5:27 pm
First time doing the phot bucket thing.
http://i584.photobucket.com/albums/ss28 ... age053.jpg
Post by g8dhe » Wed Jul 29, 2009 5:50 pm
Well its an earth connection given that its bolted to the chassis! If everything is working OK, then I'd remove it, its been added since the Bongo was made, possibly someone had an external connection to the battery in the past.
