A leak in the sun !
Rummager
A leak in the sun !
Post by Rummager » Wed Jul 29, 2009 12:02 pm
Hello all, im hoping someone can put my mind at ease! We are currently in Miami Playa about 2 hours south of Barcelona,we drove down on friday and the trusty Bongo was faultless! However i drove it earlier today with no problems but as i just went to the fridge to get another ice cold beer i happened to glance out of the door and to my horror i saw a small puddle under the bongo about halfway along on the drivers side, I have looked underneath and it seems to be dripping from a small stub pipe? now im hoping this is some sort of drain, air con perhaps as i did have it on full earlier but if it is should it still drip 2 hours later?
Thanks.
Aunt Trumpet
Re: A leak in the sun !
Post by Aunt Trumpet » Wed Jul 29, 2009 12:57 pm
Does it appear to be coming from below where you rear passenger heater controls are?
Rummager
Post by Rummager » Wed Jul 29, 2009 1:12 pm
Hi, yes it looks to be right under them and i think i ts nearly stopped (fingers crossed)
westonwarrior
Post by westonwarrior » Wed Jul 29, 2009 1:16 pm
aircon drain
99% sure
Rummager
Post by Rummager » Wed Jul 29, 2009 2:04 pm
Thanks for the help, i will enjoy the rest our holiday and not worry about the 1002 miles home! I will stick a couple of beers in the fridge for you both just incase your passing !!
westonwarrior
Post by westonwarrior » Wed Jul 29, 2009 2:06 pm
As long as you keep an eye on your coolant level (every morning) I wouldn't worry about it
kelv
Post by kelv » Wed Jul 29, 2009 3:09 pm
Mine did that in the hot weather with the rear aircon switched on.
Aircon drain.
Don't worry :lol:
Aunt Trumpet
Post by Aunt Trumpet » Wed Jul 29, 2009 3:31 pm
Rummager wrote:Thanks for the help, i will enjoy the rest our holiday and not worry about the 1002 miles home! I will stick a couple of beers in the fridge for you both just incase your passing !!
It's difficult not to worry isn't it? After all the stories you read on here, it can make you paranoid!! I've mastered the art of driving with one eye on the road and the other permanently on the temp gauge...whilst my left ear is listening for a bubbling expansion tank!! :shock: :)
madmile
Post by madmile » Wed Jul 29, 2009 6:02 pm
Put your hand under the drip - cold and clear= air con. Warm, yellow and greasy= coolant ....... :cry: .
Post by Doone » Wed Jul 29, 2009 6:27 pm
Or pink and a bit greasy if you have longlife anti freeze. :)
Ron Miel
Post by Ron Miel » Wed Jul 29, 2009 6:41 pm
Doone wrote:Or warm, pink and a bit greasy if you have longlife anti freeze. :)
Warm and yellow - buy a new Porta Potti. Well, you did say "a leak in the sun". Try to pop behind a hedge myself.
Rummager
Post by Rummager » Thu Jul 30, 2009 9:31 pm
Hi again, thanks for all the help and reassurance, i have played around with the air con and i am now happy that is what it is! i did change the hoses to silicon ones,flush the system and install a low coolant alarm before we left so fingers crossed i will make it back to blighty in a couple of weeks without any disasters.
Regards
