So I need two new ones so the garage says, trouble is the parts places are saying I need the wishbone thingy as well
which costs £139 each all in.
People in past posts have said they have just managed to fit the ball joint itself to the wishbone, but I cant find anwhere that sells them on their own.
Any advice greatfully recieved.
It would be nice and most sensible to use a press but it is possible to go the DIY route and use a hammer, drift and tube carefully as I have done, provided you tap firmly around the joint evenly to get it to go in squarely so it does not bind on the way in. Just ensure you use a drift or tube to protect vital surfaces and the rubber part. I used a few inches of scaffhold tube to hit the wish bone down over the joint supported on a stout metal support to the ground, as I said in my posts elsewhere on this topic I replaced mine in situ on the car saving the removal of the wishbone. A good warm up of the surrounding wishbone arm with a hot air gun or blow lamp will help immesurably too. Wish I had taken photos when recently doing mine now to illustrate how i did it.... if you need greater detail of the diy route please let me know.
Its great when the knocking goes, makes you wish you had done it sooner. I had a creaky drop link that eluded me for weeks, I just couldnt trace where it was coming from as the sound seemed to come from all directions, I found it by holding it while the car was being rocked and felt some slight roughness thats all........its suprising how easily these things get on your nerves.
