I have the impression from comments in several posts that when the diesel engine is started some sort of routine takes place with the turbo etc over the first few minutes. Could someone give a description of this event(s), it would be helpful to understand the different noises on startup and drive away.
Ron
what happens when a Bongo diesel is started
Re: what happens when a Bongo diesel is started
It starts to spin when enough exhaust gases to make it spin go through it.ronhud wrote:I have the impression from comments in several posts that when the diesel engine is started some sort of routine takes place with the turbo etc over the first few minutes. Could someone give a description of this event(s), it would be helpful to understand the different noises on startup and drive away.
Ron
