Help please for Bongo Fury mate in Birmingham (Dudley)
Eat Aunt
Location: Bongoing since 2005 in the Portsmouth area :)
Post by Eat Aunt » Wed Jun 10, 2009 8:18 pm
Greetings Earthlings :mrgreen:
Is there a fellow Bongolier who can help a BongoFury member in Birmingham.... (Dudley to be more precise)
His Fan Heater motor has by the sounds of it siezed up, probably due to water ingress from the usual dreaded blocked drain hole at the base of the windscreen... :shock:
A garage has removed the air intake etc and confirmed the motor is fairly well seized
If I was nearer I would nip round and do it, but am hoping someone nearer could pop round and see if the motor just needs the regulation removal, freeing up and greasing up and refitting....
If that fails where is the best place for Brian to obtain a new fan motor / resistor ?
Thanks folks in anticipation
=D>
20 YEARS BONGO-ING
Black Std 2WD AFT
Now 2001 WHITE V6 Tintop ... 253,000 Km
kelv
Re: Help please for Bongo mate in Birmingham (Dudley)
Post by kelv » Wed Jun 10, 2009 8:26 pm
It's not quite Dudley, but Ian at Market Drayton may be able to help.
He's a ( Bongo) garage though, rather than a free of charge Bongoist.
Re: Help please for Bongo Fury mate in Birmingham (Dudley)
Post by mikeonb4c » Wed Jun 10, 2009 9:44 pm
Unless he's handy enough to tackle it himself with a factsheet then maybe one from a breakers yard, or from ebay (they come up quite regularly) and/or let Ian Taylor get one and then take it to Ian Taylor and let him do it - might be best option. :roll:
bongolow
Post by bongolow » Thu Jun 11, 2009 12:40 am
The resistor may just need re-soldering - when the motor seizes up the resistor overheats and some solder connections melt inside. It's a very easy repair if you are handy with a soldering iron - there's a fact sheet on it in the member's section.
Post by Bob » Thu Jun 11, 2009 12:48 am
I think the Fact Sheet's pretty good.
BongoMTBer
Post by BongoMTBer » Fri Jun 12, 2009 7:35 pm
If he wants to bring it here one evening next week, he is more than welcome. I did mine 18 months ago and it is still happy. I drilled a drain hole in the bottom of the bearing housing.
