Where to get a fuse?
BONGODADDY
Post by BONGODADDY » Fri May 29, 2009 4:56 pm
Probably a really obvious question? :?:
I have managed to find out that my stereo and wing mirrors wouldn't operate due to a blown 15amp fuse by taking one out for something else and using that one in the slot, just wanted to know where i get a new one from, are they mazda items , i have seen them in other cheapy shops but they look a bit different to the one i have taken out so not sure if they will fit?
Any help greatfully appreciated,
PS Can i purchase a set of fuses for future problems from anywhere?
westonwarrior
Re: Where to get a fuse?
Post by westonwarrior » Fri May 29, 2009 5:04 pm
the fuse by the drivers knee
take the fuse with you any gararge will stock them
stringman
Post by stringman » Fri May 29, 2009 5:06 pm
The mini fuses are pretty much standard in many cars these days and you can pick them up at any car accessory shop, motor factors etc. The colours are occasionally slightly different but they will always have the rating written on them too.
Only thing to watch for is that a couple of manufacturers have started using a "low profile" version of the mini fuse which is different in that the blades of the fuse are recessed into the plastic but these are few and far between so it is unlikely you will even be able to get these ones yet.
Tin top Bongo camper, Peugeot Partner Combi, Kawasaki ZRX1100, Yamaha SR250SE
Post by g8dhe » Fri May 29, 2009 5:55 pm
The Bongo Shop above at the top right does a kit of all the Mini-Fuses you need.
BONGODADDY
Post by BONGODADDY » Fri May 29, 2009 6:08 pm
O:)
Thanks all, i knew i could rely on ya!!!
Post by Simon Jones » Fri May 29, 2009 9:17 pm
Another good supply is to go to the local scrapyard with empty pockets & look under the dashboard of any Japanese car :)
