changing bulbs
- peanutcrusher
- Tribal Elder
changing bulbs
how do i get the front internal light out so i can change the bulbs and what type of bulb are they
Bongo now work later !!!
- brorabongo
Re: changing bulbs
On ours it's a case of moving the whole fitting to the side, and pull down, then you can get to the plastic clips to release the lens. The Lamp type is w5w capsule, I along with others have used LED's instead of the standard......much brighter now.
- peanutcrusher
- Tribal Elder
Re: changing bulbs
does this mean you don't pull the glass out to change the bulb.
Re: changing bulbs
Pull the whole fitting out.
