oil and coolant checks
- peanutcrusher
- Tribal Elder
how often should i be checking my oil? once a week
or few thousand miles, or is this to often. Also how often should i be checking the coolant and what should i be looking for, do i just look at the outside of the bottle under the bonnet and make sure it above the low line is this enough.
Bongo now work later !!!
Re: oil and coolant checks
Hi PNC. Once a week is good, and 'yes'. Keep an eye on the age of both fluids also, relative to recommended change intervals - lots of advice on here if you use the search facility, and don't have the owner's manual (available at the Bongo Shop). Cheers.peanutcrusher wrote:how offered should i be checking my oil? once a weekor few thousand miles, or is this to often. Also how often should i be checking the coolant and what should i be looking for, do i just look at the outside of the bottle under the bonnet and make sure it above the low line is this enough.
Oh, and re coolant level, a low coolant alarm is a good investment - again, lots of info here via 'search.Ron Miel wrote:Hi PNC. Once a week is good, and 'yes'. Keep an eye on the age of both fluids also, relative to recommended change intervals - lots of advice on here if you use the search facility, and don't have the owner's manual (available at the Bongo Shop). Cheers.peanutcrusher wrote:how offered should i be checking my oil? once a weekor few thousand miles, or is this to often. Also how often should i be checking the coolant and what should i be looking for, do i just look at the outside of the bottle under the bonnet and make sure it above the low line is this enough.
- daveblueozzie
Yes weekly checks on oil, and coolant, get youself a coolant alarm from Haydn from this forum.
best buy i ever made ,saved my engine from cooking itself.
Lost without my Bongo.
Hi Dave
Just out of interest, what failed to make it almost cook itself ?
Hose, Rad or what ?
( no coolant alarm this month, so paying particular attention to possible failure areas )
Ta
Hose, Rad or what ?
Ta
you are lucky i can not find my dip stick
- mikexgough
Follow this........ http://www.youtube.com/watch?v=XyeHJUCXNVs... and all will be revealed
