Now i know the empty one at the top on the right is an AFT up warning light. (I have a tin top.)
But the one at the bottom next to the rear demist on light says belt.. & there's no bulb!
Now, i swapped bulbs & started the engine... It don't light up.. I guess it shouldn't.?
Or should it light up pre ignition check style like all the rest?
We all know why warning lamp bulbs are removed..
& bear in mind i've had no real problem in over two years.. (Except the top hose.)
What's the deal??
