17 ''s offset 52.5?
oshkosh
17 ''s offset 52.5?
Post by oshkosh » Tue Mar 24, 2009 7:58 pm
hello everyone! I need some advice please, I had planned to get some RX8 18' alloys for my bongo, but after trawling through the forum, I am now considering 17'' ( because it is cheaper and easier to find tyres with sufficient load rating etc) the problem is that the ones I've seen are 114 stud diameter but the offset is 52.5. the seller tells me he has sold loads of this size to Bongo owners and they should just fit straight on. does anyone have this size offset for 17''s? and will they have any effect with regards m.o.t etc?
thanks
Re: 17 ''s offset 52.5?
Post by bigdaddycain » Tue Mar 24, 2009 8:18 pm
Those wheels will fit straight on, the offset increases in millimeters as the wheels go wider. The bigger offset number for the wheels still fall within the tolerance from a "will my wheels stick out from the arches" point of view. They won't protude too far, and won't catch the bodywork. :wink:
oshkosh
Post by oshkosh » Tue Mar 24, 2009 8:23 pm
cheers Bigdaddy, and they'll still be legal and no problems with M.o.t?
Post by bigdaddycain » Tue Mar 24, 2009 8:29 pm
No problem whatsoever... I think wheels have to protude half an inch or so proud of wheelarches before it becomes a legal issue. The RX8 wheels still sit comfortably inside the arches on a bongo. :wink:
oshkosh
Post by oshkosh » Tue Mar 24, 2009 8:39 pm
while your online, can I ask you if Mazda do 17''s with a smaller offset, the same as the 18''s?
Post by bigdaddycain » Tue Mar 24, 2009 9:03 pm
I'm not sure on that one osh...But i'm sure somebody in the know will be along soon... :wink:
dandywarhol
Post by dandywarhol » Tue Mar 24, 2009 10:00 pm
I hadn't realised the RX8 offset was that much bigger than standard 40mm :shock: - now that's going to have an adverse effect on the vehicle safety in the event of a blowout or a brake failure!
http://www.familycar.com/alignment.htm#Scrub%20Radius
mister munkey
Post by mister munkey » Tue Mar 24, 2009 10:11 pm
oshkosh wrote: I had planned to get some RX8 18' alloys for my bongo, but after trawling through the forum, I am now considering 17''
These aren't RX8s oshys talking about here surely, just something with similar looks but a 17?
Last edited by mister munkey on Tue Mar 24, 2009 10:14 pm, edited 1 time in total.
Post by bigdaddycain » Tue Mar 24, 2009 10:12 pm
It's only 12.5 mm more dandy! My bongo was VERY stable on RX8's... I think most other peeps with them will agree that the bongo behaves much better on them than on standard sized wheels, the biggest drawback seems to be the extra associated road noise with the (usually) wider than standard tyres... :wink:
Post by bigdaddycain » Tue Mar 24, 2009 10:18 pm
Hi chris, yes... But the offset of both the 17" and 18" inch wheels are the same at 52.5 :wink:
