soft closure help req'd
				steviebongo
 - Tribal Elder
hi there can somebody help me with my soft closure door ,posted a while ago still not got to the bottom of the fault,so here goes,striped the door down and the door has got the mechanism for the soft close and the fuses are ok but can't find a wiring diagram for the door anywhere, the door has 5 pins no1 is blue and has apprx 5 volts at it no2 red and no5 black are to earth these 3 wires go directly to the motor/module inside the door. any help would be great as the wind noise and draughts from the door not closed properly are doing my head in.
cheers stevie.
						cheers stevie.
				MountainGoat
Re: soft closure help req'd
Bongo wiring diagram is available from the club shop on a CD rom. Problem with it is while a good lecky should be able to understand the symbols the anotations are in Japanese I believe.
Tony
									Tony
Former SGL5 Owner Jeep Cherokee 2.5CRD  Burstner Ixeo Time it585
In the mean time, you should be able to shut the door fully without the soft close, if you can't, I'd say the problem is more of a mechanical one. Check the runners & catches are all clear.
				steviebongo
 - Tribal Elder
thanxs the door does close and everything mechanicaly works but the door dosent fully close because the motor hasnt pulled the mechanism too close.
cheers.stevie
						cheers.stevie
Door should still close tight without motor pulling it in, prefer mine not to close electrically so remove fuse, closes fully no problem.
I'm not surprised to read this. One Bongo I looked at when hunting for one had a soft close that didn't work. I recall thinking it made virtually no difference (except possibly on a campsite late at night when you don't want to disturb peeps by slamming doors)splitpin wrote:Door should still close tight without motor pulling it in, prefer mine not to close electrically so remove fuse, closes fully no problem.
When I first got my bongo the soft close had been dissconnected and I didnt know it had it until I saw another bongo's door lock itself. mine would close tight without the softclose so if yours doesnt it must be one of the latches or if the cables to the latches in the door have become dissconnected or broken it might be stopping one of them locking correctly. after seeing the other bongo door close itself I stripped the panel off mine to see if it had the bits and it had, but the electrical connectors had been dissconnected and so had the cables which were a bitch to set up.
									smoke me a kipper i'll be back for breakfast
						- daveblueozzie
True, we peeped a new shape at wheelquick that didn't have the soft close option.daveblueozzie wrote:Not all bongos have soft close.
				rwill19050
When ours 'packed up' I found it to be corrosion on the door/pillar contacts.
A quick rub with wire wool, a wipe of WD40 and Bingo (or should I say Bongo), soft door close again.
				steviebongo
 - Tribal Elder
thanxs for the help ,looks like i,ll just put it on the things to do list ,i,ll get on to it eventually lol!!.
cheers.
						cheers.
Well, I didn't know that, Dave.daveblueozzie wrote:Not all bongos have soft close.
Mike
Curator of the Bridgwater Motorbike Collection
- daveblueozzie
Missfixit (Kirsty) told me.Yamaha wrote:Well, I didn't know that, Dave.daveblueozzie wrote:Not all bongos have soft close.![]()
Mike
Lost without my Bongo.
Kirsty is without doubt No1 techie stuff contributordaveblueozzie wrote:Missfixit (Kirsty) told me.Yamaha wrote:Well, I didn't know that, Dave.daveblueozzie wrote:Not all bongos have soft close.![]()
Mike
Dabs
Did I? Someone musta told me thendaveblueozzie wrote:Missfixit (Kirsty) told me.Yamaha wrote:Well, I didn't know that, Dave.daveblueozzie wrote:Not all bongos have soft close.![]()
Mike
