central locking
karen
central locking
Post by karen » Mon Feb 09, 2009 9:04 pm
a while ago my central locking died. ie basically each door needed opened with the key.
as i would need to take the driver's door panel etc off to look at this - i got one of the kits to install the remote key fob's and hooked that in.
the key fob has stopped working (checked spare as well). however if i open the drivers door the central locking works - but only on opening. it doesnt lock them
is this more than likely to be the controller box from the remote fob ?
Re: central locking
Post by bigdaddycain » Mon Feb 09, 2009 9:12 pm
Hi Karen, do you have a leisure battery fitted in the bongo, if so, does your interior lights work from the leisure battery?
karen
Re: central locking
Post by karen » Mon Feb 09, 2009 9:22 pm
havent checked the leisure battery lately
admittedly i did have to swap the main battery last month
i wouldnt expect looking to be related to that but i will check the status of leisure battery
maxheadroom
Re: central locking
Post by maxheadroom » Mon Feb 09, 2009 9:24 pm
Karen,
I would check the wires that come from the drivers door into the car. :D
Keep the Faith
Re: central locking
Post by bigdaddycain » Mon Feb 09, 2009 9:31 pm
karen wrote:havent checked the leisure battery lately
I may be way off mark karen, but i had a flat leisure battery last year (without realizing) I was more pre occupied with the lack of central locking.... It turned out that the central locking is one the same circuit as the interior lights, and my interior lights had been "patched" to the leisure battery, which was flat, so the central locking didn't work.
A fully re-charged LB cured the problem in my case. :wink:
Re: central locking
Post by missfixit70 » Mon Feb 09, 2009 10:12 pm
Good call Ste, I had the same last year when my LB was iffy.
Re: central locking
Post by Bob » Mon Feb 09, 2009 11:37 pm
My CL just packed up, went intermitent for a couple of weeks, typicaly unlocking, then refusing to re-lock.
No LB fitted, and it's too cold to be outside messing with it. If I get a chance I'll be starting at the loom to the driver's door, otherwise it's in for service on Friday so I may just ask the garage to sort it.
At least it's packed up properly, intermitent faults are a right pig. :(
