no battery warning light, no charge help needed fast
fordavefreda
Post by fordavefreda » Tue Feb 03, 2009 6:03 pm
help needed fast, recently been repairing freda and i arced across alternator connection by accident, now i dont have a battery warning light and no charge going to batteries! have i blown a fuse somewhere? all the ones i can see seem fine which fuse would be in the circuit?
help greatfully appreciated as freda is stranded!!
cheers dave
Re: no battery warning light, no charge help needed fast
Post by francophile1947 » Tue Feb 03, 2009 6:14 pm
Is everything else working? I can't see a specific fuse for just the alternator light :?
fordavefreda
Post by fordavefreda » Tue Feb 03, 2009 6:20 pm
yes the alternator puts out a charge but i don't think its getting to batteries?? when i turn on ignition you usually have a battery light on the dash which illuminates then goes out when you start up unless theres a problem, well my light desent illuminate at all?! i would have thought there would be a fuse protecting the circuit?
cheers for help
Post by missfixit70 » Tue Feb 03, 2009 6:24 pm
What is the alternator putting out? Have you checked the main fuses under the bonnet? - http://www.igmaynard.co.uk/bongo/member ... usebox.pdf
Post by missfixit70 » Tue Feb 03, 2009 6:26 pm
fordavefreda wrote:yes the alternator puts out a charge but i don't think its getting to batteries?? when i turn on ignition you usually have a battery light on the dash which illuminates then goes out when you start up unless theres a problem, well my light desent illuminate at all?! i would have thought there would be a fuse protecting the circuit?
cheers for help
Do any of the dash lights illuminate?
fordavefreda
Post by fordavefreda » Tue Feb 03, 2009 6:29 pm
all fuses under bonnet seem fine which ones the alternator fuse?
Post by francophile1947 » Tue Feb 03, 2009 6:30 pm
What makes you think it's not getting to the battery? Do the headlamps go brighter when you rev the engine? It may just be a blown bulb.
fordavefreda
Post by fordavefreda » Tue Feb 03, 2009 6:30 pm
all other dash lights are fine!
Post by francophile1947 » Tue Feb 03, 2009 6:31 pm
fordavefreda wrote:all fuses under bonnet seem fine which ones the alternator fuse?
Don't know, as I said earlier, there isn't an obvious fuse covering that circuit.
Post by missfixit70 » Tue Feb 03, 2009 6:33 pm
Don't think there is an alternator fuse, isn't it cabled direct to the battery? I think you may have fubarred the alternator.
Have you measured voltage output from alternator? is it high 13 to 14+volts?
Post by bigdaddycain » Tue Feb 03, 2009 6:59 pm
I think you may be right kirsty, i'm sure the alternator is fuesd via the main starter battery, i think it's the big blue fuse rated at 100 amps that lives in the little box bolted to the battery.
fordavefreda
Post by fordavefreda » Tue Feb 03, 2009 7:56 pm
if that fuse was to blow would that cause the battery light not to work? if i think back i think it looks ok but that could be differenr it might look ok but, i'll have to get out the multimeter! when i do a charging check do i just stick the multimeter to the battery and start up and see if theres an increase in voltage?
cheers dave
Post by bigdaddycain » Tue Feb 03, 2009 8:06 pm
fordavefreda wrote:if that fuse was to blow would that cause the battery light not to work?
I'd imagine so dave, if it's blown then the circuit is incomplete. Often those big fuses can pop at the narrow end, and can often appear (visually) to be fine. I'd definitely check for continuity of the fuse with your multimeter. :wink:
Post by francophile1947 » Tue Feb 03, 2009 8:37 pm
fordavefreda wrote:when i do a charging check do i just stick the multimeter to the battery and start up and see if theres an increase in voltage?
cheers dave
That will work :D
Post by bigdaddycain » Tue Feb 03, 2009 8:40 pm
Sorry, i missed that bit! #-o Use the multimeter to check that fuse too dave. :wink:
