Any thoughts/ comments?!
Trouble at t'Mill
Post by Trouble at t'Mill » Fri Nov 14, 2008 10:30 pm
Or, better still, has anyone tried this?
http://cgi.ebay.co.uk/MAZDA-B2500-BONGO ... 240%3A1318
Cheers.
westonwarrior
Re: Any thoughts/ comments?!
Post by westonwarrior » Fri Nov 14, 2008 10:39 pm
it's A ball bearing thats used to blank off the egr i think.
The claims are a bit extreme I think
I would suggest better to get the blanker from allans who advertise on here and has many happy customers (I am meaning to order one myself and you have reminded me to do so.)
May be a bit more but proven.
Post by missfixit70 » Fri Nov 14, 2008 10:44 pm
all it does is block the signal pipe to the egr control unit I think, not a lot of good if the EGR itself is crudded up & can't close. I did mine with a small bolt & blanked the egr & removed it, loads on the forum if you do a search :D
Trouble at t'Mill
Post by Trouble at t'Mill » Sat Nov 15, 2008 9:50 am
Thanks folks.
That was my suspicion, but the ad says "NO FITTING A BLANKING PLATE BETWEEN THE EGR VALVE AND MANIFOLD.", which probably means it's a BB instead as you say!
Thanks.
bongomaan
Post by bongomaan » Sat Nov 15, 2008 11:52 pm
the word rhymes with rollocks....i went for it ...waste of money...typical newbie ebay blag. Allans egr kit...the dogs rollocks....
Nevets
Post by Nevets » Sun Nov 16, 2008 9:28 pm
I've just this week fitted blanking plates(Allans) cost £6 each 2 required.
Plus a bottle of diesel injector cleaner and even her indoors has noticed the slight increase in power/consumtion and the cleaner exhaust..
=D> =D>
I am the only bongo in the village.......(not anymore there's two of us now "Damn it)
Post by Bob » Sun Nov 16, 2008 11:57 pm
We've got Allan's blanking plates, well worth it.
Trouble at t'Mill
Post by Trouble at t'Mill » Mon Nov 17, 2008 2:04 pm
Thanks for the comments.
Are peeps recommending fitting these EGR blanking plates as standard, even if you don't have a 'smoke' problem?
Cheers.
Post by bigdaddycain » Mon Nov 17, 2008 7:14 pm
Trouble at t'Mill wrote:Thanks for the comments.
Cheers.
I don't see why not, i blanked my EGR system with it working ok... Saves the hassle of having a smoking bongo at some time in the future whilst waiting for the kit to arrive... :wink:
Trouble at t'Mill
Post by Trouble at t'Mill » Tue Nov 18, 2008 12:35 am
Ha ha, cheers bigdaddycain.
