Which Glowplugs Do You Use?
How Reliable Are Your Plugs
I use Blueprint and never have any problems
0
No votes
I used Blueprint but found them unreliable
3
11%
I use NGK plugs and never have any problems
4
14%
I used NGK plugs but found them unreliable
0
No votes
I use other plugs and never have any problems
1
4%
I have used other plugs but found them unreliable
2
7%
I have never needed to change the plugs
14
50%
My garage does this for me
1
4%
Don't Know or Other Response
3
11%
Total votes: 28
Post by Ian » Thu Nov 13, 2008 11:50 am
I spoke to Dandywarhol about this yesterday, and he told me that he has never had any problem with NGK plugs, but when he's used ADM-Blueprint plugs in the past, they had a tendency to blow. So I thought I would conduct a poll, and find out if there is a serious reliability issue with the Blueprint plugs.
BTW, the relevant parts numbers for the 83mm plugs are ADM 51805, NGK Y701J and Durite DU013026.
You may select up to 2 answers in this poll.
dandywarhol
Re: Which Glowplugs Do You Use?
Post by dandywarhol » Thu Nov 13, 2008 3:34 pm
I've just replaced a couple of Blueprints which had failed in 6 months. I also changed a couple of Bprints last year which were fairly new.
More worrying was when an unknown brand with a green band around the top and the number FC5320 stamped on it - the complete "glow" part of the plug came adrift and dropped into the pre-combustion chamber :shock:
kawasaki kid
Post by kawasaki kid » Thu Nov 13, 2008 9:42 pm
Also had to replace a set of Blueprint plugs after 12 months due to poor starting :x replaced them with a set of Genesis twin coil glow plugs - no problems with them up to now after nearly 12 months. :)
If I had all the money I ever spent on my Freda ............ I`d spend it on my Freda.
Peg leg Pete
Post by Peg leg Pete » Thu Nov 13, 2008 10:10 pm
We have had our Bongo three and a half years and still on same glow plugs, not sure of make :roll:
Image Pete
Mike Jill and Emily
Post by Mike Jill and Emily » Fri Nov 14, 2008 9:10 am
I suspect my plugs are duff (or at least one of them is) so once I have checked which ones are fitted (van has a new cyl head) I will be ordering the NKG (not heard of the Genesis - must be a bit noisy with Phil Collins drumming all the time they are on :roll: )
robdrinky
Post by robdrinky » Fri Nov 14, 2008 12:50 pm
last week i fitted 4x adk81801(blueprint)102mm glowplugs to rectify poor starting from cold.
previous plugs were in when we got the bongo so i dont know how old they are(but at least a couple of years old)and cannot make out which brand they are.
will just have to see how it goes with the new ones 8)
the voices made me do it!
P reg unconverted blue/grey 2.5td AFT
