bonnet prop thingy
meek.tv
bonnet prop thingy
Post by meek.tv » Wed Nov 12, 2008 2:49 pm
ok the wind caught my bonnet theother day when it was open and propped up on its stick thingy (proper techie terms here)
it snapped the plastic hinge and dented my bonet at the same time
ive got a new plastic hinge bit but i have no idea how to fit.....any pointers?
cheers
.......... cycling more.
MountainGoat
Re: bonnet prop thingy
Post by MountainGoat » Wed Nov 12, 2008 3:08 pm
The same thing happened to me last year when I broke down on the Western Isle during a storm. The plastic retainer for the bonnet stay sort of slides into place. It took a bit of fiddling about before I cottoned on how to do it.
Post by francophile1947 » Wed Nov 12, 2008 4:03 pm
If I remember correctly, I had to fit the rod into the plastic thing before it went into the hole in the bonnet - I know it took me a while to figure it out :oops: :oops:
Post by Simon Jones » Thu Nov 13, 2008 1:25 am
I think you fit it in & twist it into position. I'll try to get a photo tomorrow of it in position (if I remember).
meek.tv
Post by meek.tv » Thu Nov 13, 2008 10:32 am
pic would be really helpfull if you can
probably wont happen today as its raining :(
Post by Simon Jones » Thu Nov 13, 2008 3:16 pm
Got picture, but will need to use by other laptop at work to send it via bluetooth, so should have it here for 9am tomorrow.
Post by Simon Jones » Fri Nov 14, 2008 4:05 pm
Sorry about the delay in posting these pictures. As far as I can see, the plastic clip fits into the hole & is then rotated until it clicks into place as shown below:
meek.tv
Post by meek.tv » Fri Nov 14, 2008 5:01 pm
thats really helpfull thanks. i will have a go in the morning if its dry
cheers
snowrat
Location: Huddersfield when not in the Tatry, Andes & Himalaya Mountains
Post by snowrat » Fri Dec 05, 2008 7:40 pm
Worked for me after a little fiddling with the clip to get it in the right position.
Had to put the clip in first about 90 deg anti-clockwise from its finishing position, then rotate clockwise into correct position as shown in the photo. The put straightest end of arm in on the horizontal pointing out to the right, after which you move it 180 deg clockwise into it's correct position.
Snowrat
2WD 2.5TD in the Snow
Chamonix | Chile & Argentina Summer Skiing
