fuel guage
Jake
fuel guage
Post by Jake » Sun Sep 07, 2008 9:37 pm
sorry not been on for ages but life seems to have been a bit hectic, any way to busy playing out during those long hot summer evenings!!!! :oops: :oops:
Fuel guage not working prob the sender i guesse, any ideas on cost
Also during the wet season my passenger window (electric) was really struggling to come back up, any suggestions???? :?
Jake x
Rhod
Re: fuel guage
Post by Rhod » Sun Sep 07, 2008 9:46 pm
Fuel guage could just be the earth on the sender unit? There were a few posts a while back with detailed instructions on wiring a new earth, so try a search. Cleaning the earth contacts solved my under-reading gauge for a bit, but I need to rewire for a permanent solution when I get a chance..
Rhod
maxheadroom
Re: fuel guage
Post by maxheadroom » Mon Sep 08, 2008 6:21 am
Keep the Faith
daveblueozzie
Re: fuel guage
Post by daveblueozzie » Mon Sep 08, 2008 8:10 am
as above for the fuel guage ,usually an earth wire.
the window might be an even easier fix, a can of silicon spray/grease and spray it into the window runners, worked for me.
Lost without my Bongo.
Heifer
Re: fuel guage
Post by Heifer » Mon Nov 03, 2008 11:54 pm
Ahhhhh!!!!
I've had a fuel gauge problem for a while. Expecting it to be simply an earth problem, when I finally lifted the carpets and fitted an alternative earth, I was miffed to find that the gauge was still not working. Digging out my trusty multi-meter, I established that the original earth was fine, although the voltage I got using both the original and new earth was around 3 volts. Should I have been getting 12 volts?
Anyway, convinced that the earth was ok, I turned my attention to the sender (removed). Twiddling the dial on my multi-meter, I figured that resistance didn't vary as I move the float. Working on the theory that the sender works as a variable resistor, I thought I'd found my problem, only have replaced the sender I'm still running on empty! :x
I've taken out the dashboard and checked all the connectors there - nothing. I'm now out of ideas and am wondering whether there is anything obvious I can do to try and fix the problem.
Many thanks.
Heifer's frustrated other half
Re: fuel guage
Post by Bob » Tue Nov 04, 2008 12:02 am
Haven't got a fix for your problem, but as a stop-gap if you zero the trip meter when you fill up, topping up at 250 miles should give you a good reserve.
maxheadroom
Re: fuel guage
Post by maxheadroom » Tue Nov 04, 2008 2:46 am
Heifer wrote:Ahhhhh!!!!
Many thanks.
Heifer's frustrated other half PM sent :D
Keep the Faith
