Odometer stuck
Peg leg Pete
Odometer stuck
Post by Peg leg Pete » Thu Aug 21, 2008 8:54 pm
Our Bongo clocked up 89999 miles and now refuses to move any further, tripometer has ceased to move also, Speedometer is working fine, any suggestions please as to how to rectify the problem :)
Image Pete
westonwarrior
Re: Odometer stuck
Post by westonwarrior » Thu Aug 21, 2008 9:01 pm
Have you tried resetting the trip?
have you tried taking it out and knocking the dials on a notch?
Peg leg Pete
Re: Odometer stuck
Post by Peg leg Pete » Thu Aug 21, 2008 9:02 pm
Tried resetting trip, did not alter anything, will have to have a look tomorrow , thanks for your swift response Rob :wink:
Image Pete
You've Been Bongod
Re: Odometer stuck
Post by You've Been Bongod » Thu Aug 21, 2008 9:16 pm
hi pete it isnt your chip playing up is it ?
you've been bongod
Re: Odometer stuck
Post by Bob » Thu Aug 21, 2008 9:21 pm
Mine was a bit sticky after I took out the speedo to conect the cruise, I'm with Rob that taking it out and gently jiggling it could free the dials.
Rhod
Re: Odometer stuck
Post by Rhod » Thu Aug 21, 2008 9:32 pm
Mine stuck as it turned 99999 miles. Resetting the trip didn't work, but a good hard tap on the plastic screen while driving did the trick. Otherwise I would try removing the dash & manually turning it with a small screwdriver.
Re: Odometer stuck
Post by teenmal » Fri Aug 22, 2008 12:18 am
Just give the last wheel a prod with a match stick.(the blunt end)
Mal..
Peg leg Pete
Re: Odometer stuck
Post by Peg leg Pete » Fri Aug 22, 2008 10:00 pm
Cheers for advice, not a chipped speedo, Have not had a chance to remove speedo today, will hopefully get to have a look on Sunday :wink:
Image Pete
mobilecat
Re: Odometer stuck
Post by mobilecat » Sat Aug 23, 2008 8:22 pm
Let us know if you get this one sorted. My trip meter sticks but so far the totals are ok. My trip gets stuck under a mile or goes ok so I always know if its working or not.
Peg leg Pete
Re: Odometer stuck
Post by Peg leg Pete » Sun Sep 28, 2008 6:00 pm
Well never did get chance to remove speedo to sort out the stuck guage :roll: Set off at 3.30 a.m. yesterday to take Matthew to work, drove over curb to avoid reversing up the street, as we were travelling along noticed that the tripometer and odemeter had decided to start working again :wink:
Image Pete
