O2 sensor (lambda)
O2 sensor (lambda)
Does anybody know if there is a universal sensor that will fit the V6 my99. All of the uk sites i have found only list two wire sensors with a black and a white wire, mine is a blue and a white wire?
Re: O2 sensor (lambda)
Goin on previous posts pretty universal, do a search lambda sensor i've just looked at it but can't attach it, A couple of others dealt with it last year, my local back street motor factor seems to be a night in shining armour for me
Hi there,
I had mine changed. From memory they are a standard size and it's a 2 wire model. Look to pay around £30 for a reasonable one. If you change yourself be careful when removing that you don't strip the threads and only use the grease supplied on the threads of the new one, standard grease etc can contaminate and damage the sensor.
Google it and there is a specialist website that tells you all you need to know.
Andy
Andy
Hi Andy what colour are the wires on yours?
Blue and white from memory but I'll take a look tomorrow, don't think colour is important on a 2 wire sensor though.
Andy
Andy
