got the horn?
got the horn?
Help,noob ere.Just imported my bongo & sent it for its first MOT.It failed on o/s/f lower ball joint worn & horn inop,is it possible to replace only the ball joint as i keep getting quoted for a complete lower arm & where have those pesky japs hidden the horn.Would like to test it but searched hi & lo,cant find it
- maxheadroom
Re: got the horn?
Hi wes 68, the horn is sort of behind the offside headlight and yes you can replace the ball joint only but you need a press. They can be found on eBay I think.wes 68 wrote:Help,noob ere.Just imported my bongo & sent it for its first MOT.It failed on o/s/f lower ball joint worn & horn inop,is it possible to replace only the ball joint as i keep getting quoted for a complete lower arm & where have those pesky japs hidden the horn.Would like to test it but searched hi & lo,cant find it
Re: got the horn?
Hi Wes 68, mine failed it's MOT recently with the same ball joint. I found it difficult to find someone to supply the ball joint alone. In the end I went for the easier but more expensive option and bought the full monty. Bell Hill Garage £153 then add postage on top £193.wes 68 wrote:Help,noob ere.Just imported my bongo & sent it for its first MOT.It failed on o/s/f lower ball joint worn & horn inop,is it possible to replace only the ball joint as i keep getting quoted for a complete lower arm & where have those pesky japs hidden the horn.Would like to test it but searched hi & lo,cant find it
Re: got the horn?
Hi Wes,there are two horns roughly behind head lights.
Near side high tone,off side low tone.
Have you checked the fuse.
Mal
Mal
Re: got the horn?
cheers mal,not sure which fuse it is but ran a meter over all of them & didnt find a fault.Can hear relays clicking when i press horn switch so assume fuse okteenmal wrote:Hi Wes,there are two horns roughly behind head lights.
Mal
Re: got the horn?
hi raff,got a ball joint on the way £45.Bit late for you i know but got it from mazdabongo.shopRaff wrote:Hi Wes 68, mine failed it's MOT recently with the same ball joint. I found it difficult to find someone to supply the ball joint alone. In the end I went for the easier but more expensive option and bought the full monty. Bell Hill Garage £153 then add postage on top £193.wes 68 wrote:Help,noob ere.Just imported my bongo & sent it for its first MOT.It failed on o/s/f lower ball joint worn & horn inop,is it possible to replace only the ball joint as i keep getting quoted for a complete lower arm & where have those pesky japs hidden the horn.Would like to test it but searched hi & lo,cant find it
Re: got the horn?
There is normally only one standard "beep beep" type, below the offside headlight, the second must be an option on some models.teenmal wrote:Hi Wes,there are two horns roughly behind head lights.
Mal
So don't worry if you can't find two.
Re: got the horn?
Hi Wes,glad to see you got your ball joint.
If you have time stick it in the freezer for a day before you fit it.
You will find it goes into the wish-bone easier.
Cheers Mal...
Cheers Mal...
Re: got the horn?
If the horn relay is clicking test the horn conections with a 12v bulb, if that works just fit a replacement horn (from a scrappie?) to the 2 wires and bolt in place.
And welcome aboard.
And welcome aboard.
Re: got the horn?
Or fit some of these electric air horns - http://cgi.ebay.co.uk/AIR-HORN-SET-2-TO ... .m14.l1318 - they fit in the space behind the headlight & are much beter than the originals
Re: got the horn?
Thanks for tips everybody.Me horn was missing & the wire tucked nicely inside the inner wing,traced it,tested it & fitted a new horn.Just the run of the mill "toot" "toot",tho i did consider a general lee or col bogey air horn!
Re: got the horn?
Thats good,the original horns are C#~p anyway.
Cheers Mal..
Cheers Mal..
