100 amp fuse...
bongomaan
100 amp fuse...
Post by bongomaan » Wed Jul 23, 2008 5:28 pm
can someone tell me if the blue 100 amp fuse behind the main battery is male or female mine has welded itself in and someone has wrapped fuse wire around it and i need to sort it pronto but they are a fiver each and if i told you how much i have spent on this motor this month i would faint and so would you... cheers..neil..
Re: 100 amp fuse...
Post by Ian » Wed Jul 23, 2008 7:03 pm
It's not welded, it's bolted on from underneath and is a sod to get off. Can't remember if it's male or female though.......
waycar8
Re: 100 amp fuse...
Post by waycar8 » Wed Jul 23, 2008 7:08 pm
it has 2 prongs that go into the fuse holder, then a bolt goes through the side of the fuse holder and into the prongs, holding it in place
bongomaan
Re: 100 amp fuse...
Post by bongomaan » Wed Jul 23, 2008 8:06 pm
thank you guys.
bongomaan
Re: 100 amp fuse...
Post by bongomaan » Thu Jul 24, 2008 7:01 pm
the blue 100 amp fuse is male (with prongs ) and has two 10 mil bolts holding it in , i fond it easier to remove battery clamp and gently pull thick red wire to access bolt at the back of the fuse box....
