Noisy sterring wheel
mobilecat
Post by mobilecat » Tue Jun 17, 2008 6:14 pm
I noticed today that my steering wheel is rather noisy - it seems to be making a noise rather like that of a squeeky windscreen wiper when turned.
Any takers?
Dolly1
Re: Noisy sterring wheel
Post by Dolly1 » Tue Jun 17, 2008 6:17 pm
Hi,MC
Any silicon spray will do the job.
SARAH & LIONEL - I Used to be Citroen 2CV "DOLLY" mad but BONGO-MAD lady with not so mad husband now!
mobilecat
Post by mobilecat » Tue Jun 17, 2008 7:49 pm
Dolly1 wrote:Hi,MC
Ok now for my blond attack - where from and where to? Is it urgent and does someone want to help?
jaylee
Post by jaylee » Tue Jun 17, 2008 8:02 pm
You sure the cowls not loose & just rubbing on the back of the wheel at some point??
mobilecat
Post by mobilecat » Tue Jun 17, 2008 8:13 pm
jaylee wrote:You sure the cowls not loose & just rubbing on the back of the wheel at some point??
I will check that tommorrow thanks. I haven't looked into it at all - I was just really suprised to hear noises coming from it!
cheffy34
Post by cheffy34 » Tue Jun 17, 2008 8:55 pm
Just a thought is it definitely coming from the cowling or could it be further down the steering columb:?: I always look for worst case senario then chuffed when it turns out easy fix :lol: :wink:
mobilecat
Post by mobilecat » Tue Jun 17, 2008 8:58 pm
cheffy34 wrote:Just a thought is it definitely coming from the cowling or could it be further down the steering columb:?: I always look for worst case senario then chuffed when it turns out easy fix :lol: :wink:
I wasnt sure and haven't had time to incestigate properly but it does sound pretty local - it had better be anyway :)
Post by mikeonb4c » Tue Jun 17, 2008 10:47 pm
Let's leave incest out of this please MC. Way too local for my liking :wink: :lol: 8)
mobilecat
Post by mobilecat » Tue Jun 17, 2008 10:53 pm
My flipping keyboards!!
Post by bigdaddycain » Wed Jun 18, 2008 1:49 am
Is the power steering fluid level full?
mobilecat
Post by mobilecat » Wed Jun 18, 2008 8:12 am
Oh crumbs now you are asking.
mobilecat
Post by mobilecat » Wed Jun 18, 2008 8:17 am
After the school run I will attempt to check the cowl, see if anything else is obvious and try and get to the power sterring fluid - I haven't tried to access under the driver seat since the conversion :oops:
If it is the power steering fluid - where do I get this from?
Post by bigdaddycain » Wed Jun 18, 2008 10:04 am
Yep, the reservoir is under the drivers seat cat, if it does need topping up you'll need some hydraulic fluid/power steering fluid/auto gearbox fluid. I think its available in places such as morrison's/tesco etc nowadays... Just check the section where you'll find the engine oil for sale. :wink:
mobilecat
Post by mobilecat » Wed Jun 18, 2008 10:25 am
bigdaddycain wrote:Yep, the reservoir is under the drivers seat cat, if it does need topping up you'll need some hydraulic fluid/power steering fluid/auto gearbox fluid. I think its available in places such as morrison's/tesco etc nowadays... Just check the section where you'll find the engine oil for sale. :wink:
I will have a look when it stops raining - I am soaked just from the school run!! As it happens I didnt actually hear the noise this morning.
Post by bigdaddycain » Wed Jun 18, 2008 10:30 am
It could simply be a bit of debris caught between the wheel and the cowling, or the cowling may have "jumped" one of its "jaws"... But if you haven't checked the level of the fluid for a while, then you may as well have a gander... :wink:
