nightmare day
rob and karen
nightmare day
Post by rob and karen » Wed May 28, 2008 6:32 pm
well all , have had a nightmare day , coming back from bideford today and heard a bang then the battery and sediment light came on , i thought no i have thrown a belt , pulled over in a safe place by now there was a humming noise as well , threw the passenger seat up and found the alternator pulley missing :? , seems the pulley has sheared off and threw both belts off cant find the pulley just the alternator with the shaft and bolt , anybody else had this problem ?? need to find a pulley and try putting it back on the alternator
rob
robdrinky
Re: nightmare day
Post by robdrinky » Wed May 28, 2008 6:47 pm
sorry to hear about that-not a nice thing to happen.as for parts perhaps a breakers(bellhill for example)or via ebay .
dont forget ians partfinder.
best of luck and hope its fixed soon. 8)
the voices made me do it!
P reg unconverted blue/grey 2.5td AFT
Re: nightmare day
Post by mikeonb4c » Wed May 28, 2008 6:51 pm
Ouch. Sounds scary but not bank ruining, which is good in a bad sort of way. Is the alternator pulley not part of the alternator unit i.e. a replacement will come with a pulley on it? Expect I'm being dumb here so will await corrective training on this thread.
Hope you get it sorted OK. 8)
rob and karen
Re: nightmare day
Post by rob and karen » Wed May 28, 2008 7:13 pm
Thanks chaps
i think i have an old alternator with the pulley still on will have to sort through the shed and pull it out and put the pulley on the van alternator hopefully it will work ok (crossed fingers)
rob
Re: nightmare day
Post by mikeonb4c » Wed May 28, 2008 8:43 pm
Interesting one Rob - good luck and keep us posted. 8)
Re: nightmare day
Post by Simon Jones » Thu May 29, 2008 12:11 am
Sorry to hear of your woes. Dont forget Westward Leisure on A39, just west of Fairy Cross: John is bound to have something lying around.
dandywarhol
Re: nightmare day
Post by dandywarhol » Thu May 29, 2008 12:12 pm
Check the thread on the shaft isn't damaged - try to find out why the pulley came off - it's usually either a nylock nut or a plain nut with spring waher which means it shouldn't come undone - especially as the direction of rotation would always by trying to tighten the nut :shock:
rob and karen
Re: nightmare day
Post by rob and karen » Thu May 29, 2008 2:32 pm
hi guys
well stripped it off today to take a look , this is what i found
luckily i had an alternator that had gone T**s up so , took both to my local garage and they changed the pulleys over for £5 for me brought it back re-fitted and sorted all working fine 8)
bongo back in business
Simon Jones wrote:Sorry to hear of your woes. Dont forget Westward Leisure on A39, just west of Fairy Cross: John is bound to have something lying around.
cheers simon i got the bongo from john he didnt have anything there when i rang him but offered help if i needed it , doesnt seem to be a common thing although john had it happen to him on a motorway once , so i would only assume that over time maybe the alternator nut comes loose slightly and tehrefore the pulley starts to slip and wears , so guys i would check this everytime you have the seat up :shock:
cheers rob
Veg_Ian
Re: nightmare day
Post by Veg_Ian » Thu May 29, 2008 2:48 pm
Nasty. Never seen anything like that before.
westonwarrior
Re: nightmare day
Post by westonwarrior » Thu May 29, 2008 3:40 pm
wow
I am pleased its sorted
do you know was the pully held in place with a woodruf key or by high tourque on the bolt?
Re: nightmare day
Post by mikeonb4c » Thu May 29, 2008 4:33 pm
Wow - weird one. Has it sheared all round and come off? Was the retaining nut loose then, and that caused it?
V glad its fixed and at minimal £ :lol:
rob and karen
Re: nightmare day
Post by rob and karen » Thu May 29, 2008 6:47 pm
westonwarrior wrote:wow
No woodruff key just force on the nut and a collered washer behind
mikeonb4c wrote:Wow - weird one. Has it sheared all round and come off? Was the retaining nut loose then, and that caused it?
nuts wasnt loose , buy wasnt super tight also so im putting it down to possible casting defect and also possible nut not correctly tightned up
other than that its going well once again :lol:
dandywarhol
Re: nightmare day
Post by dandywarhol » Thu May 29, 2008 6:53 pm
I'd keep my eye on it R & K - there's been a lot of heat in that shaft by the "blueing" on the threads :shock:
brorabongo
Re: nightmare day
Post by brorabongo » Thu May 29, 2008 7:14 pm
My old alt is still in two bits, as I wait to get my nut removed, so I can to check/replace front bearing ( if I can get hold of one). I'll need to get a garage to remove the nut, as I could not shift it. :oops:
Well spotted, on the blueing
ボンゴの激怒 pictures
rob and karen
Re: nightmare day
Post by rob and karen » Thu May 29, 2008 7:16 pm
dandywarhol wrote:I'd keep my eye on it R & K - there's been a lot of heat in that shaft by the "blueing" on the threads :shock:
that was the camera flash lol the pulley when it came loose caught the top thread on its way off so the camera flash picked up the mark it made when it flew off :roll: , am deffo keeping an eye on it now though another thing to check when doing routine checks lol
rob
