Cylinder Head Torque setting and sequence?
anfarrow
Post by anfarrow » Mon May 26, 2008 10:05 pm
Hi - does anyone know the torque value and the sequence? Thanks
Re: Cylinder Head Torque setting and sequence?
Post by Simon Jones » Mon May 26, 2008 10:14 pm
29Nm (in 3 to 4 rounds) then 90 - 105 degrees, then another 90 - 105 degrees. The sequence is difficult to describe so I have a diagram I can email you if you pm me your address. You'll need a 14mm 12 cornered socket to fit the heads.
Post by Simon Jones » Tue May 27, 2008 9:47 am
I used the info in the manual - but I did give them an extra 'nip' at the end, as some felt like they more slack in than others.
dandywarhol
Post by dandywarhol » Tue May 27, 2008 8:27 pm
Simon Jones wrote:I used the info in the manual - but I did give them an extra 'nip' at the end, as some felt like they more slack in than others.
Kinda defeats the use of a torque wrench surely Simon :?
New bolts should be used every time because they "stretch" to the predetermined setting by the manufacturer - an extra nip could put them beyond the elastic limit and then they are in danger of becoming loose or could shear.
Post by Simon Jones » Wed May 28, 2008 1:04 am
Following the instructions in the manual, they are tightened to 29Nm & then 90-105 degrees, plus another 90-105 degrees. Give or take the error on the torque wrench, plus the 180-210 range on the angular rotation, I think its only going to be a couple of degrees over. The bolts were replaced a few weeks ago, but the head has been removed & installed again since then. They were less the max length specified in the manual, so I'm hoping they will be fine. I guess time will tell.
