Jolly Rogers
Post
by Jolly Rogers » Sat May 17, 2008 1:02 pm
As you have most probabley read, I am having a few problems at the moment with the Bongo.
I thought the battery was dead.
Went to Halfords this morning and brought a battery charger which connects via the cigarette lighter adapter, followed the instructions. The green led came on straight away to indicate the battery is charged. However when I turn the ignition no power at all.
Advice gratefully received
Post
by missfixit70 » Sat May 17, 2008 1:04 pm
Wouldn't think it'd be much good unless your lighter socket is connected direct, normally it's only on with ignition.
waycar8
Post
by waycar8 » Sat May 17, 2008 1:04 pm
do you have an immobaliser fitted?, if not check the main fuses under the bonnet, i think its a 100 amp fuse for the ignition/engine ect.
Jolly Rogers
Post
by Jolly Rogers » Sat May 17, 2008 1:09 pm
I have checked the 100amp fuse
There is no fuse just a piece of insulated wire.
waycar8
Post
by waycar8 » Sat May 17, 2008 1:12 pm
Jolly Rogers wrote:I have checked the 100amp fuse
sounds like you have found the problem then
, lets just hope it the wire that has blown and nothing else
silly question but have you wiggled the wire to see if the bongo will start?
Dolly1
Post
by Dolly1 » Sat May 17, 2008 1:19 pm
Hi,have you tried reclamping battery terminals
SARAH & LIONEL - I Used to be Citroen 2CV "DOLLY" mad but BONGO-MAD lady with not so mad husband now!
Jolly Rogers
Post
by Jolly Rogers » Sat May 17, 2008 1:29 pm
Tried all that no Joy!
Is there a simple and safe way to check to see if the battery has any power?
MountainGoat
Post
by MountainGoat » Sat May 17, 2008 1:41 pm
Local auto electricians tested mine for free. Why don't you try them or your local battery supplier.
Post
by missfixit70 » Sat May 17, 2008 1:48 pm
Jolly Rogers wrote:Tried all that no Joy!
Multimeter across the terminals reading voltage, should be around 12v or more, up towards 14v with the engine running charging it.
Jolly Rogers
Post
by Jolly Rogers » Sat May 17, 2008 2:04 pm
Just tried car horn connected direct to battery no sound, tried on the wife's meriva
I think i have just peforated my ear drum.
Conclussion
Battery is flat
Halfords battery charger is rubbish.
Still having ringing in my ears
Looks like another trip to halfords.
Post
by Bob » Sat May 17, 2008 3:09 pm
Some chargers won't start charging if the battery is completely flat. Found this with my fancy new one, after charging with my very old, cheap, charger for a couple of hour to get some chage in swaped to new one - fine.
maxheadroom
Post
by maxheadroom » Sat May 17, 2008 3:46 pm
Jolly Rogers wrote:Just tried car horn connected direct to battery no sound, tried on the wife's meriva
Conclussion
Battery is flat
pardon
Keep the Faith
The Great Pretender
Post
by The Great Pretender » Sat May 17, 2008 11:38 pm
Easy peasy connect a wire to each terminal, poke tounge out, then put the other ends of the wires on your tounge. Great voltage sensor.
To infinity and beyond
cheffy34
Post
by cheffy34 » Sat May 17, 2008 11:51 pm
cheffy34
Post
by cheffy34 » Sat May 17, 2008 11:54 pm
I find my ratchet a good voltage sensor when i end up welding it to the inner wing whilst playing with the battery
and yes i have done it before
