Advice please
Jolly Rogers
Advice please
Post by Jolly Rogers » Sat May 17, 2008 1:02 pm
:? As you have most probabley read, I am having a few problems at the moment with the Bongo.
I thought the battery was dead.
Went to Halfords this morning and brought a battery charger which connects via the cigarette lighter adapter, followed the instructions. The green led came on straight away to indicate the battery is charged. However when I turn the ignition no power at all.
Advice gratefully received [-o<
Re: Advice please
Post by missfixit70 » Sat May 17, 2008 1:04 pm
Wouldn't think it'd be much good unless your lighter socket is connected direct, normally it's only on with ignition.
waycar8
Re: Advice please
Post by waycar8 » Sat May 17, 2008 1:04 pm
do you have an immobaliser fitted?, if not check the main fuses under the bonnet, i think its a 100 amp fuse for the ignition/engine ect.
Jolly Rogers
Re: Advice please
Post by Jolly Rogers » Sat May 17, 2008 1:09 pm
I have checked the 100amp fuse :shock: There is no fuse just a piece of insulated wire.
waycar8
Re: Advice please
Post by waycar8 » Sat May 17, 2008 1:12 pm
Jolly Rogers wrote:I have checked the 100amp fuse :shock: There is no fuse just a piece of insulated wire.
sounds like you have found the problem then :shock: , lets just hope it the wire that has blown and nothing else [-o<
silly question but have you wiggled the wire to see if the bongo will start?
Dolly1
Re: Advice please
Post by Dolly1 » Sat May 17, 2008 1:19 pm
Hi,have you tried reclamping battery terminals
SARAH & LIONEL - I Used to be Citroen 2CV "DOLLY" mad but BONGO-MAD lady with not so mad husband now!
Jolly Rogers
Re: Advice please
Post by Jolly Rogers » Sat May 17, 2008 1:29 pm
Tried all that no Joy!
Is there a simple and safe way to check to see if the battery has any power?
MountainGoat
Re: Advice please
Post by MountainGoat » Sat May 17, 2008 1:41 pm
Local auto electricians tested mine for free. Why don't you try them or your local battery supplier.
Re: Advice please
Post by missfixit70 » Sat May 17, 2008 1:48 pm
Jolly Rogers wrote:Tried all that no Joy!
Multimeter across the terminals reading voltage, should be around 12v or more, up towards 14v with the engine running charging it.
Jolly Rogers
Re: Advice please
Post by Jolly Rogers » Sat May 17, 2008 2:04 pm
Just tried car horn connected direct to battery no sound, tried on the wife's meriva :shock: I think i have just peforated my ear drum.
Conclussion
Battery is flat
Halfords battery charger is rubbish.
Still having ringing in my ears
Looks like another trip to halfords.
Re: Advice please
Post by Bob » Sat May 17, 2008 3:09 pm
Some chargers won't start charging if the battery is completely flat. Found this with my fancy new one, after charging with my very old, cheap, charger for a couple of hour to get some chage in swaped to new one - fine.
maxheadroom
Re: Advice please
Post by maxheadroom » Sat May 17, 2008 3:46 pm
Jolly Rogers wrote:Just tried car horn connected direct to battery no sound, tried on the wife's meriva :shock: I think i have just peforated my ear drum.
Conclussion
Battery is flat
pardon :lol:
Keep the Faith
The Great Pretender
Re: Advice please
Post by The Great Pretender » Sat May 17, 2008 11:38 pm
Easy peasy connect a wire to each terminal, poke tounge out, then put the other ends of the wires on your tounge. Great voltage sensor. :wink:
To infinity and beyond
cheffy34
Re: Advice please
Post by cheffy34 » Sat May 17, 2008 11:51 pm
:lol: :lol: :lol: :lol: :lol:
Must try that one TGP :shock:
cheffy34
Re: Advice please
Post by cheffy34 » Sat May 17, 2008 11:54 pm
I find my ratchet a good voltage sensor when i end up welding it to the inner wing whilst playing with the battery :roll:
and yes i have done it before :oops:
