fuel sender access
fuel sender access
Post by missfixit70 » Wed May 14, 2008 9:03 pm
As requested Ian, photos of the fuel sender cover on & off, have emailed you the photos too
Arrow pointing towards front (mid seats reversed)
Re: fuel sender access
Post by Ian » Wed May 14, 2008 11:31 pm
Cheers Kirsty. So which one is the sender unit? And what are the others?
Post by missfixit70 » Wed May 14, 2008 11:41 pm
I don't know, I just took the photo :lol: I'd guess it's the squarish connector bock top rightish? all the others seem to be pipes, didn't poke around as it had a nice film of waxoyl & I wasn't getting grubby today :wink:
dandywarhol
Post by dandywarhol » Thu May 15, 2008 10:20 am
The whole assembly is the sender unit Ian - the electrical connector is top right, there's a fuel feed and return plus 2 breather pipes by the look of it - one probably for the fuel filler neck.
The unit is replaced as a complete assembly but most problems are with a bad earth. The easiest remedy is to make and connect a short piece of wire with an eylet on it at one end to attach to one of the crosshead screws - the other end to a suitable earthing point on the body - jobs a carrot! :D
