Whiff of coolant (i think) form blowers
GICarey
Post by GICarey » Sun May 04, 2008 5:06 pm
Hi all,
Driving bongo today, parked up, and got a little whiff of what I think is coolant smell out of the blowers. Have now noticed it each time I've been out for a run since (twice). (runs 100 miles; 10 miles; 10 miles)
No noticable loss of coolant from the header tank when the machine has had a chance to cool down, so I don't think fluid is jetting out anywhere, but in light of the numerous "coolant loss" tales of woe here on the forum, I'm (understandably?) a little concerned.
Any suggestions as to what the problem might be (heater matrix with a pin hole? something similar?) and tests to perform to investigate?
many thanks!
Gavin.
Peg leg Pete
Re: Whiff of coolant (i think) form blowers
Post by Peg leg Pete » Sun May 04, 2008 7:14 pm
I get that smell in very damp conditions :roll: No loss of coolant, think it is time to spray the Dettox into the heater fan again :wink:
Image Pete
GICarey
Post by GICarey » Sun May 04, 2008 7:21 pm
Heh, funny you should say that! Have had a closer look
From the staining under the bonnet, I think el-Bongo has had a bit of an overheat at some point in it's history, and there's still a bit of a whiffy coolant smell under there (I suspect some coolant smelling gas also escapes the header-tank now n again). Have given it a bit of a clean out under there, and squirted a little bit of neutradol into the heater-air-intake thingy under the bonnet. See if that sorts it out!
Gav.
Peg leg Pete
Post by Peg leg Pete » Sun May 04, 2008 7:23 pm
That is where I spray thanks to tip from mikeon4bc :wink:
Image Pete
