Fuel Tank Breather?
alexxb
Fuel Tank Breather?
Post by alexxb » Mon Apr 21, 2008 5:11 pm
does anyone know where the fuel tank breather is? Can you just get a replacement fuel cap with breathable holes in it?....
all was fine until I decided to take my Bongo to get the fuel sender replaced as the fuel dial was bust. Since then, the only way I can avoid coming to a grinding halt after 30 mins is to leave the diesel fuel cap on loose to allow air in?
I assume this must be a fuel breather issue - something maybe clogged up while replacing the sender? Is it easy to resolve or is it back to the garage?
Thanks!!!! :oops: #-o
maxheadroom
Re: Fuel Tank Breather?
Post by maxheadroom » Mon Apr 21, 2008 5:24 pm
alexxb,
try this link :D hope it helps. :D
http://tinyurl.com/3vokoq
Keep the Faith
alexxb
Post by alexxb » Mon Apr 21, 2008 7:49 pm
cool - I'll pin it next to the bed! Thanks ;)
dandywarhol
Post by dandywarhol » Mon Apr 21, 2008 10:06 pm
I know the law doesn't allow these venting caps on petrol engined vehicles these days - fumes have to go through a charcoal filter first - not so sure about diesels....................
This any help? - 42590A is a breather valve and connects up to the filler neck (Z)
http://www.lushprojects.com/bongoparts/ ... l).html#19
