Dear all im seeking your advice re a problem that i have created regards my glow plugs. I replaced the plugs but the new ones were shorter than the old ones in the main body (not actual plug end). It would seem that this has caused the bar which goes across the plugs to touch the fuel injectors and fuse out. I have looked at the fuse diagrams and there is no problem with number 18 fuse (for glow plugs). Has anyone any ideas where i go next ? Maybe the relevant relay? Any help greatfully received as im about to head of on a trip:)
Many Thanks
Gary
Help.... re glow plugs
Re: Help.... re glow plugs
the glow plug relay is under the bonnet, bolted on the side of the inner wheel arch at the back of the battery, mine has a clear plastic sleve over it
hope it helps
hope it helps
Thanks for this, i can see x2 relays covered by black ribber for protection, are these the ones? They sit behind the battery on the inner whell arch. Or is there another one i have missed?
Gary
Gary
It's the rear one - nearest the bulkhead. You should hear it click when you turn the ignition on.
if you lift the rubber housing, it says glow plug relay on it (well mine does anyway)
