Little black button with a red dot
trevorjtaylor
Post by trevorjtaylor » Sun Mar 23, 2008 2:53 pm
Hi. Just got my Ford Freda yesterday. Pleased so far. To the right of the steering column there's a little black toggle swith with a little red dot on it. What does it do? Haven't pressed it yet in case its the ejector button.
Trevor
Post by mikeonb4c » Sun Mar 23, 2008 2:55 pm
Is it the rear foglight switch - they often use little round switches with a small red light in them as part of the 'dangly' foglight job they do to get imported Bongos through the MOT?
Post by missfixit70 » Sun Mar 23, 2008 3:34 pm
Yep, most likely rear fog light, but make sure you're not too attached to whoever is sat in the passenger seat just in case :wink: Welcome to the forum & enjoy, don't be shy asking what you can't find.
trevorjtaylor
Post by trevorjtaylor » Sun Mar 23, 2008 5:28 pm
Thanks all. Does indeed seem to be the foglight.
Much obliged.
Watch this space for more stupid questions!
T
Post by mikeonb4c » Sun Mar 23, 2008 6:23 pm
At the risk of spouting corny philosophy, in the Bongo Tribe the only stupid question is the one that isn't asked 8)
HA106420
Post by HA106420 » Sun Mar 23, 2008 6:24 pm
How come a 2nd switch is requird for the fog light?Just checked the wiring and it simply connects up to the original fog light switch on the dash.
I also have a similar switch on the left of my steering wheel that connects to the 12v cig plug (this wire is fused) whilst the 2nd wire is not connected / loose.
Post by mikeonb4c » Sun Mar 23, 2008 7:37 pm
HA106420 wrote:How come a 2nd switch is requird for the fog light?Just checked the wiring and it simply connects up to the original fog light switch on the dash.
Good question. I don't have an original foglight switch so can't answer but maybe your Bongo had (front?) foglights and the vendor used the switch for the rear foglamp. Question then is where did the original foglights disappear to.
Don't all write in at once :lol: :lol: :lol:
maxheadroom
Post by maxheadroom » Sun Mar 23, 2008 7:40 pm
eBay :roll: :evil: :roll:
Keep the Faith
Post by mikeonb4c » Sun Mar 23, 2008 8:35 pm
Max - behave! :lol:
eight wheeler
Post by eight wheeler » Sun Mar 23, 2008 9:19 pm
do they have fog in japan
coco bongo
Post by coco bongo » Sun Mar 23, 2008 9:25 pm
Onry pea soup, take ten minit in miquorave
eight wheeler
Post by eight wheeler » Sun Mar 23, 2008 9:32 pm
think about it fog in a tin they could import it off us to test there fog lights
Post by Bob » Mon Mar 24, 2008 12:51 am
eight wheeler wrote:think about it fog in a tin they could import it off us to test there fog lights
Then charge bl**** VAT on it.
jaylee
Post by jaylee » Mon Mar 24, 2008 3:34 am
I have a similar set up with the fogs..
I have factory fitted front fogs that eluded Customs & importers eBay eyes disguised as 4 kilo's of Moroccan.. & the rear fog takes a feed off that! :D
The switch on the left could be for a heated rear screen?? :idea:
HA106420
Post by HA106420 » Mon Mar 24, 2008 12:36 pm
I was thinking that the switch was for front fogs....even though the van has no front fogs! Will further investigate.
As for the rear heated window screen, the button doesnt link ito the wiring for it, it only links into the cig lighter connection.
Cheers all
