Sorry in advance if this is a repeated subject.
My sliding door quiet closure system doesnt work. The previous owner had a Viper Alarm and central locking system fitted and Im just wondering if this is the likely cause of it not working.
Anyone got any thoughts or experience of the same thing?
Ames
Sliding door closure
Try cleaning the brass plunger contacts with some fine emery cloth & make sure the ones that move are moving freely, squirt of wd40? do the runners top & bottom while you're at it.
Is the door itself opening & closing ok, ie not getting stuck in the locked position?
- westonwarrior
Small switch on the edge of door itself is for the child lock to prevent it being opened from the inside.
1995 N reg 2WD AFT in green/grey
www.whiteroseancestry.co.uk
