trip switch on leisure battery
- Bongonaut
My mechanic suggested that he put a trip switch on the leisure battery instead(i think) of fuses as suggested on previous threads. Does this sound like a good idea ?
spe llink d*ue to Kirsty's sloe Brndy!
- Bongonaut
When you first start the engine, there is probably a short initial current surge when the charging relay closes.
Fuses are slow to react and are able to cope with this surge. Trips react much faster and may trip on the initial surge.
If this were the case, you would never charge your leisure battery !!!!.
