New battery
curlew
New battery
Post by curlew » Thu Jan 10, 2008 2:36 pm
I've just had Bongo's battery replaced - 79.99 fitted. Is this good, average or exorbitant?
Post by mikeonb4c » Thu Jan 10, 2008 2:47 pm
Sounds average -> good to me, though I know some do better. Depends on what AmpHr it is etc. - it should be a 95AmpHr or thereabouts for that price I'd have thought
Post by Bob » Thu Jan 10, 2008 6:34 pm
Sounds about right to me.
maxheadroom
Post by maxheadroom » Thu Jan 10, 2008 7:18 pm
sounds good to me, I payed £94
Keep the Faith
londonron
Post by londonron » Fri Jan 11, 2008 6:59 pm
while doing up my boat i get to learn far too much to be healthy on loads of things , i have recently learned about batteries.
the answer is that its not that simple to base it on cost. it is what you got for the money you spent as depending on the thickness of the plates and how you use it will lengthen or shorten the life of it.
reason i had to know was i needed 3 batteries at 100 pound each and was told they will need changing every 2 or 3 years and thought like xxxx they will. if you intend getting a lesuire battery for camping etc its well worth spending a rainy day understanding how they work so you can make a good choice. i managed to find batties for 65 pound each with a 4 year guarantee as a result.
moonshine
Post by moonshine » Sat Jan 12, 2008 12:01 am
What type of boat have you got? That's mine on the left, coming up river through Wapping Reach.
Re: New battery
Post by bigdaddycain » Sat Jan 12, 2008 12:05 am
curlew wrote:I've just had Bongo's battery replaced - 79.99 fitted. Is this good, average or exorbitant?
I'd say that was a fair enough price, as Londonron suggests, how good a guarantee came with it curlew?
londonron
Post by londonron » Sat Jan 12, 2008 2:33 am
i have an empty shell of a narrow boat. its 45ft long and has all the same principles when wiring as a car in regard to 12volt with 240 hook ups and in board water storage etc. i understand very little as its learn what i need for the next task. am doing the electrical system at the moment involving batteies, invertors and chargers as well as all the pump and bits that go with it.
