Fuel pump seems partially blocked
I had my Bongo serviced before Christmas, running sweet and pulling well. A few days later noticed slight fuel leak. Found it was seals around fuel pump. Got them replaced, then the fun started!
The garage grunt unwittingly put sealant around the new seals, and this seems to have got squished, and some sucked into the pump. Now it won't go over 3000 revs and is VERY underpowered, as you would expect with fuel starvation.
I went back, and reluctantly, the garage tried to sort it by blowing air through etc. After 3 weeks i got it back with, "try that" (still no better!), and "by the way, I've sold garage" from the owner....
So now i have under performing Bongo and no one to go and do a Victor Meldrew too.
Before I go down the line of a second hand pump, are there any last tips/ideas I could try? Could it be something elemental that has been put back wrong. A strip down of the pump will cost a fortune, so second hand pump seems only way forward.
Thanks for any ideas
Mark
Mark
Quite right John, and/or your local Trading Standards. Do not let him walk away - sends the wrong signal to anyone else inclined to behave similarly.francophile1947 wrote:I think you should contact the Citizen's Advice Bureau cos' I think the garage owner may still be liable - he'll also have plenty of money to pay for it if he's sold the place.
There was an injector/pump for sale on ebay recently though it may have gone. If not, Bongos are being broken all the time.
Honestly though, what a bunch of t*ssers.
Good luck
Mike
- The Great Pretender
It maybe worth asking here.
http://www.vegetableoildiesel.co.uk/forum/
There are some really bright guys there.
- Tribal Elder
Hi Gwyddfor, i experienced a similar problem after having work done on my fuel pump ,it turned out it was only dirt collected in the tiny banjo filter. It is very easy to check this ,you would be able to do it yourself and if it does turn out to be would save you a lot of heartache and money . It's got to be worth checking? Should you need any help in locating the banjo filter there should be a diagram on here somewhere or feel free to PM me
Simon
I'm Bongoing mad R U?
