air con ?
You've Been Bongod
air con ?
Post by You've Been Bongod » Mon Dec 03, 2007 10:41 pm
put me air con on tonight to clear windscreen and what a bloody racket sounded like bongo falling apart :-k
very loud squeeling noise and grinding sound which got worse the more i was revving it so will have to check belts tommorrow only just had air con serviced about 3 months ago so should work ](*,) ](*,)
any suggestions PLEASE
you've been bongod
Post by Bob » Mon Dec 03, 2007 10:44 pm
If it hasn't been used for 3 months that may well be the problem. There is information on here somewhere about this, but a common problem here is our climate is fairly mild (honestly) and if the aircon isn't used the seals dry out.
This won't fix it, but may help prevent further trouble.
Good luck.
dreamwarrioruk
Post by dreamwarrioruk » Mon Dec 03, 2007 10:45 pm
you sure theres not a cat in there, i can understand the squealing noise but the grinding must be the cats collar,
sorry the only sugestion ive got is the belts but the grinding dosnt sound good.
You've Been Bongod
air con ?
Post by You've Been Bongod » Mon Dec 03, 2007 10:48 pm
dreamwarrior if there was a cat in there i think it would have died but cant smell anything lol
i used the aircon about a week ago and it was fine
will have to investigate when light
thanks for replies so far
you've been bongod
dreamwarrioruk
Post by dreamwarrioruk » Mon Dec 03, 2007 10:55 pm
its recommended that the air con is run for 5 minutes once a week to stop the seals going dry. maybe thats what you got stuck in there.
you been to any sealife centres lately carl
You've Been Bongod
air con ?
Post by You've Been Bongod » Mon Dec 03, 2007 11:03 pm
no sealife centres dreamwarrior just a freezing cold BUXTON maybe motor is frozen :-k
you've been bongod
