remove heater vents on dash
hi all!! any ideas on how to remove these vents??? if you can? thanx!!
From behind, squeeze in the sides slightly, they are retained by the pivot points. If it's the middle ones, you may have to take the climate control unit out ( see s.w.blackmores excelllent thread http://www.igmaynard.co.uk/bongo/forum/ ... hp?t=16703 to do this) and either the glove box/ clocks or unscrew the side panels under the dash to be able to reach up behind. Bit of a bugger reconnecting the ducting properly when I did it
Contortionism is always useful
