remove heater vents on dash
bongoboarder
Post by bongoboarder » Fri Nov 30, 2007 11:14 pm
hi all!! any ideas on how to remove these vents??? if you can? thanx!! :?
Post by missfixit70 » Fri Nov 30, 2007 11:38 pm
From behind, squeeze in the sides slightly, they are retained by the pivot points. If it's the middle ones, you may have to take the climate control unit out ( see s.w.blackmores excelllent thread http://www.igmaynard.co.uk/bongo/forum/ ... hp?t=16703 to do this) and either the glove box/ clocks or unscrew the side panels under the dash to be able to reach up behind. Bit of a bugger reconnecting the ducting properly when I did it :roll: Contortionism is always useful :wink:
