Very basic battery question
mobilecat
Post by mobilecat » Sat Oct 27, 2007 7:03 pm
If I open the door of my van and turn on the light to show my vehicle off etc. I presume the battery drain would be minimal as long as I remember to turn it off, even if it was on for some time. I haven't had a vehicle capable of leaving any lights on EVER in my life so I am a little paranoid.
Post by Muzorewa » Sat Oct 27, 2007 7:07 pm
The battery should stand the interior lights being on for yonks and still have enough oomph to start it - just like you should be able to leave the parking lights on for hours :wink:
Post by Muzorewa » Sat Oct 27, 2007 7:09 pm
......although I know someone who drained his battery after several hours with the CD player & interior lights, and with an auto couldn't get going without the intervention of the RAC - an embarrassing one with his latest popsy in the passenger seat :roll:
dp bradford
Post by dp bradford » Sat Oct 27, 2007 7:12 pm
When I first got my Freda I went camping in Wales and sat all evening reading a book by the light of the florescent strip light assuming it was wired to the leisure battery - it wasn't :shock: The van started OK though :D I have since modified the wiring to have all the internal lights running from the leisure battery :roll:
Dave
platty345
Post by platty345 » Sat Oct 27, 2007 7:20 pm
cat, has it got twin batts?
mobilecat
Post by mobilecat » Sat Oct 27, 2007 7:59 pm
platty345 wrote:cat, has it got twin batts?
No it hasn't got twin batteries so I have space for a leisure when Im ready. I wasnt convinced about the current battery as I knew it was flat last time I was there so he put me in a new one as I watched today before I drove away:)
Post by bigdaddycain » Sun Oct 28, 2007 4:18 pm
The bulbs in the front (cabin area) are very easily replaced with l.e.d bulbs too mobilecat, which uses next to nothing battery power.... These are much brighter too :wink:
The pic was taken in the daytime too! :wink:
trevd01
Post by trevd01 » Sun Oct 28, 2007 4:36 pm
The interior lights are like any other vehicle, with three positions
On
Off
On when door is opened.
So you can leave the lights on in a Bongo, only in the same way as any other car :?
scanner
Post by scanner » Sun Oct 28, 2007 5:04 pm
Exactly, why are you turning on yourself at all?
Put it in the auto position and it's the same as the fridge
door open=light on
door closed=light off
The only difference is that you can tell it's off with the Bongo, with the fridge you can never really be sure, can you???????
mobilecat
Post by mobilecat » Sun Oct 28, 2007 5:20 pm
scanner wrote:Exactly, why are you turning on yourself at all?
door open=light on
Have you never been inside to check.
