mobilecat
Post
by mobilecat » Sat Oct 27, 2007 7:03 pm
If I open the door of my van and turn on the light to show my vehicle off etc. I presume the battery drain would be minimal as long as I remember to turn it off, even if it was on for some time. I haven't had a vehicle capable of leaving any lights on EVER in my life so I am a little paranoid.
Post
by Muzorewa » Sat Oct 27, 2007 7:07 pm
The battery should stand the interior lights being on for yonks and still have enough oomph to start it - just like you should be able to leave the parking lights on for hours
Post
by Muzorewa » Sat Oct 27, 2007 7:09 pm
......although I know someone who drained his battery after several hours with the CD player & interior lights, and with an auto couldn't get going without the intervention of the RAC - an embarrassing one with his latest popsy in the passenger seat
dp bradford
Post
by dp bradford » Sat Oct 27, 2007 7:12 pm
When I first got my Freda I went camping in Wales and sat all evening reading a book by the light of the florescent strip light assuming it was wired to the leisure battery - it wasn't
The van started OK though
I have since modified the wiring to have all the internal lights running from the leisure battery
Dave
platty345
Post
by platty345 » Sat Oct 27, 2007 7:20 pm
cat, has it got twin batts?
mobilecat
Post
by mobilecat » Sat Oct 27, 2007 7:59 pm
platty345 wrote:cat, has it got twin batts?
No it hasn't got twin batteries so I have space for a leisure when Im ready. I wasnt convinced about the current battery as I knew it was flat last time I was there so he put me in a new one as I watched today before I drove away:)
Post
by bigdaddycain » Sun Oct 28, 2007 4:18 pm
The bulbs in the front (cabin area) are very easily replaced with l.e.d bulbs too mobilecat, which uses next to nothing battery power.... These are much brighter too
The pic was taken in the daytime too!
trevd01
Post
by trevd01 » Sun Oct 28, 2007 4:36 pm
The interior lights are like any other vehicle, with three positions
On
Off
On when door is opened.
So you can leave the lights on in a Bongo, only in the same way as any other car
scanner
Post
by scanner » Sun Oct 28, 2007 5:04 pm
Exactly, why are you turning on yourself at all?
Put it in the auto position and it's the same as the fridge
door open=light on
door closed=light off
The only difference is that you can tell it's off with the Bongo, with the fridge you can never really be sure, can you???????
mobilecat
Post
by mobilecat » Sun Oct 28, 2007 5:20 pm
scanner wrote:Exactly, why are you turning on yourself at all?
door open=light on
Have you never been inside to check.
