Driver Side Window Switch Problem
markmck
Post by markmck » Sun Oct 07, 2007 6:39 pm
Just back from my last camping trip of the year at Barns Ness, near Dunbar. Perfect location and weather.
On the way home I wnet to opn my window and the switch made a 'buzzing' noise and the window never moved. I stopped, opened the door, shut it again and the windoe worked. Later on I tried to shut the window and same problem. This time I had to open and shut door a few times and it eventually worked.
Has anyone experienced this problem or know what causes it and hoe to resolve it
Many thanks for your help
Mark
Post by Ian » Sun Oct 07, 2007 6:50 pm
Loose wire in the channel between driver's door and front of vehicle. Happens quite a lot.
markmck
Post by markmck » Sun Oct 07, 2007 9:55 pm
Thanks Ian.
I'm glad its a common fault. Can you give me some direction on how to locate and fix the fault please.
Mark
Post by Ian » Sun Oct 07, 2007 11:25 pm
Trace the wire from the window switch to the plastic channel that appears when you open the driver door. It often cracks.
