Glowplugs?
Uglee
Glowplugs?
Post by Uglee » Sun Oct 07, 2007 11:50 am
First off Hello again its been a while thanks to a faulty hard drive. Anyway I am now back armed with new P.C.
Been having starting probs from cold. Glowplug light goes off after a few seconds, if I try to turn engine over it really struggles. Leave ignition on for about a minute I can hear a click and then usually starts.
Have just got to be patient in the cold weather or is this a sign of trouble?
Post by francophile1947 » Sun Oct 07, 2007 4:57 pm
When you say the engine struggles, do you mean it's slow turning over or just doesn't start? If it just doesn't start, it could well be glowplugs.
Uglee
Post by Uglee » Sun Oct 07, 2007 6:11 pm
It wont start, until I leave ignition on for ages. It aint the battery cos it iis trying to turn over not slow like when the battery is flat.
How hard is it to get at the glowplugs?
dreamwarrioruk
Post by dreamwarrioruk » Sun Oct 07, 2007 6:33 pm
sounds like a glowplugs dropped out, they are easy to get to apart from the rear two, they are hidden away behind the bundle or wires and pipes for the erg valve/ air con.
theres a rail with a wire fastened to it, remove that then the glowplugs, mind you dont drop the little nuts.
Uglee
Post by Uglee » Sun Oct 07, 2007 7:02 pm
Cheers. Will try and have a look tomorrow when i get back from work. :roll:
Post by bigdaddycain » Mon Oct 08, 2007 11:17 am
Don't forget that their are different size glowplugs for the bongo uglee,i couldn't be bothered with the whole removing of the plug...checking the size...waiting for them to arrive rigmarole :roll:
I booked my bongo in with mike at wheelquick,i had my glowplugs replaced, and the E.G.R. system removed using nick skidmore's blanking/removal kit. It took around an hour for both jobs. :wink:
dreamwarrioruk
Post by dreamwarrioruk » Mon Oct 08, 2007 5:56 pm
if there the long 102mm then they are very hard to get hold of. (like ours)
modified the rail to get the smaller ones to fit. if everyone went to the garage then there wouldnt be anyone around to help out diy repairs.
ie on saturday i only went to say hi to carl and ended up replacing the steering wheel and indicator bulbs with dbo.
Post by bigdaddycain » Mon Oct 08, 2007 6:11 pm
I know what you mean mike...steering wheels and indicator bulbs i can handle (i've dabbled with those before) but, personally, i have never swapped a set of glowplugs over,so rather than buggering it up,i let the pro's take care of it.
There's always the issue of the current arcing on the engine block if the wrong size are fitted, i realize that the rail can be raised or lowered to suit,but in my case i really would have been guessing if a problem had occured.
