bulb replacement for side lights
tridentlee
Post by tridentlee » Sat Oct 06, 2007 4:47 pm
a job for tomorrow will be to replace nearside front side light bulb, just had a quick look as i am going out tonight but cant seem to get access to rear of unit without taking unit out is this correct ? i await your knowledge, cheers lee,
dont forget next sunday shorne country park 10.30am in the car park, hope to see you there.
You've Been Bongod
Post by You've Been Bongod » Sat Oct 06, 2007 9:17 pm
hi there trident lee to get at front sidelight undo screw on top of indicator lense then simply pull gently to remove and you will find the required bulb
you've been bongod
pippin
Post by pippin » Sat Oct 06, 2007 9:31 pm
It is different on the post '99 New Shape.
Colin Lambert
Post by Colin Lambert » Sat Oct 06, 2007 10:29 pm
Well done Pips helpful to the end (Hymer traitor :lol: )
Trident Lee. If in fact yours is 99 on the bulbs can be reached from inside the engine bay via access to the back of the lamp unit.
tridentlee
Post by tridentlee » Sun Oct 07, 2007 10:35 am
thanks folks job has been done, cheers for your help, lee
