a job for tomorrow will be to replace nearside front side light bulb, just had a quick look as i am going out tonight but cant seem to get access to rear of unit without taking unit out is this correct ? i await your knowledge, cheers lee,
dont forget next sunday shorne country park 10.30am in the car park, hope to see you there.
bulb replacement for side lights
- You've Been Bongod
hi there trident lee to get at front sidelight undo screw on top of indicator lense then simply pull gently to remove and you will find the required bulb
you've been bongod
you've been bongod
