How to stop wind ?
How to stop wind ?
Is there any way to stop the non fan assisted 'breeze' which blows gently through the air vents with everything on tha aircon controls switched off ?
All my other vehicles have little levers which close the air vents, but the bongo doesn't, so there is a constant breeze from the vents caused by the movement of the vehicle through the air.
OK, I can switch it to aim at my feet or my face, but there seems to be no way of stopping it.
When the temp inside is just fine I don't want drafts blowing round the cab.
Any way to stop air coming in when it's not wanted ?
Digi climate control. Off button pressed and display just showing direction of air flow (face, feet or demist windscreen) but air still comes through.Colin Lambert wrote:air con or digital Climate control.
If the latter hit the 'off' button (bottom right)
The off button does not seem to shut off the vents.
Don't know if this is a problem in my system or if it's how all bongos work.
Odd not to have a vent shut off lever on the individual vents though. All me previous vehicles with aircon or climate control have had a vent close lever.
Same problem on a hot day, I like cold air blowing on me when I'm driving but Mrs Lovejoy doesn't so she has to angle her vent to hit the window or in my direction(ish) but still gets the effect as she can't shut off her side vent.
- haydn callow
Thanks - at least now I know mine is behaving 'normally' and it is not something which needs fixing.
I find the constant flow of fresh air to the face keeps me awake, which is a shame when the seat is so comfy and I don't have to wake up to change gears or anything.
I'll just have to up the meds to counteract the waking effect of the breeze.
